Calipers + Breakdiscs
Old Jul 7, 2004 | 11:30 PM
jazzarb's Avatar
Default Calipers + Breakdiscs
My car doesnt get driven much,at the moment and the calipers are all getting rusty, as well as the brake discs.
do you know of anyone who is able to get the rust removed? i dont really want to buy a new set of front + rears
Old Jul 7, 2004 | 11:42 PM
eSeM's Avatar
You can sort out the calipers by painting them black (or bling, bling red if you so wish).
If you use a wire brush attachment on a drill/dremel you can easily clean them up ready to paint.
Old Jul 8, 2004 | 03:26 AM
lower's Avatar
the rust will come off the discs as soon as you start to use the car again. its not something to worry about.
richard
Old Jul 8, 2004 | 03:34 AM
jazzarb's Avatar
True, but there seems to be 2 permanent rings of rust with the middle fine....
is there anyway this will disappear?
Old Jul 8, 2004 | 03:42 AM
chrisr111's Avatar
The discs are always going to rust.
Chris.
Old Jul 8, 2004 | 03:49 AM
SideWaysOnFire's Avatar
Honda brakes do seem to suffer from this quite a bit.
The rings i take it are ,centre and outer of the disc,if so that's because the pads dont quite fit the hole of the disc.
What i did with my last discs was took them off and used asome wire wool ,wire brush,and stone grinder to take the rust off,then painted the centre of the disc and the outer edge,it seem to work ok,pait was high tempture so as not crake and flake.Hope this helps.
The best way is not look at them and take it out once a week!
Old Jul 12, 2004 | 06:12 AM
BerlinaTom's Avatar
Just bought a X reg Berlina Black S with black interior and think it would look good with "bling bling" red calipers, but not sure. What's the general opinion on this? What paint would I need and where would I get it?
The car is awesome.
Old Jul 12, 2004 | 07:05 AM
douglasr's Avatar
Mine was the same after winter. Slowly disappearing now that I'm driving the car more...
skmick
Sep 18, 2012 02:48 PM
barbara4044
Aug 23, 2009 12:59 PM
TwistedS2k
Feb 26, 2005 09:30 AM
cdel
Nov 28, 2004 03:02 AM
slbutler
Apr 10, 2004 09:58 AM
