Camera Mounts
I was looking for camera mounts suitable for use in the car and came across this:
http://www.cameragrip.co.uk/acatalog/window_pod.html
Has anyone tried one of these? I was thinking you could mount it on the wind deflector but I am worried the weight may just make it tip forward into the folded position.
Take a look at Sportscam or RFconcepts.
Websites are easy to find.
They do some very nice autofocus separate bullet cams that plug into your camcorder and are much lighter and easier to mount anywhere on your car.
I use an ultra clamp in a similar fashion to the one linked. the problem is that the deflector itself wobbles around, moreso with a heavier camera.
Ultra clamp http://www.fastfilms.co.uk/fixed-camera-mounts.php £20
and for a windscreen mount a quad sucker http://www.fastfilms.co.uk/quad-sucker-win...amera-mount.php
Here are the results of the two together.
[media]http://www.youtube.com/watch?v=7MMkzus9WbM [/media]
Ah, I posted the wrong vid, here's the right on. The small window in the top left which is the deflector mounted camera, a lightweight Nikon Coolpix S1.
[media]http://www.youtube.com/watch?v=bfIW3zWF6r4 [/media]
The main pic is from the windscreen mount (which you can see in the deflector mounted view)
RossP - I would personally not go with that Manfrotto one simply because it means you've got to have the window open, which isn't ideal if it's raining, and you'll get a load of unwanted wind noise.
I have a Modifry lower profile mount which works very well
I have one of these
http://www.fastfilms.co.uk/manfrotto-pump-...lt-top-head.php
bit pricey but discounts throught the benefit section, superb mount, you get a lovely clear shot with no vibration.
Originally Posted by Kawasakivtec,Apr 28 2010, 03:27 PM
I have one of these
https://www.s2ki.com/forums/index.php?showt...&#entry18074281
That's what I would go for, if I was so inclined.
