can't start the engine...
Old Jul 26, 2007 | 01:48 PM
Ste_Nova's Avatar
Originally Posted by Lloyd Six,Jul 26 2007, 01:46 PM
S2000 engines sit on hydralic mounts which do give quite a bit so in a med frontal the ground wire from the N/S under chassis rail upto the engine can snap causing voltage issues across all the sensors.
jump lead from neg on battery to engine block and try it
Old Jul 26, 2007 | 01:51 PM
Lloyd Six's Avatar
[QUOTE=Ste_Nova,Jul 26 2007, 01:48 PM] jump lead from neg on battery to engine block and try it
Old Jul 26, 2007 | 01:52 PM
algeusis's Avatar
Originally Posted by Dark Blue Mark,Jul 26 2007, 01:34 PM
I normally give a more technical response but in this case, its sounds pretty ****ed.
its not too bad as it sounds. had more dameged cars.
car is x reg, it hav hit something like lamppost i think, so bumper, bonnet is dameged, though radiators are ok
it happend in May, maybe this could cose this problem
Old Jul 26, 2007 | 01:56 PM
Lloyd Six's Avatar
Mind that spelling, you will get hung on here trust me!!!
Can you do a picture of the damage?
It does sound like engine shunt, try the lead from the NEGATIVE post on the battery to the engine block.
Lloyd
Old Jul 26, 2007 | 01:58 PM
algeusis's Avatar
so just take of negative off battery on engine block and then start the engine??? corect?
Old Jul 26, 2007 | 02:00 PM
algeusis's Avatar
Lloyd
sorry for my mistakes, not first language
Old Jul 26, 2007 | 02:06 PM
GrittyShaker's Avatar
[QUOTE=Lloyd Six,Jul 26 2007, 10:56 PM] Mind that spelling, you will get hung on here trust me!!!
Old Jul 26, 2007 | 02:07 PM
MB's Avatar
MB
Member
No you need to connect a new lead from the battery -ve terminal and attach it to the earth point under the chassis, which the gearbox sensors use.
What Lloyd is suggesting is that the earth which the sensors use is damaged, so you are getting the fault codes light up.
Old Jul 26, 2007 | 02:08 PM
MB's Avatar
MB
Member
Its more acceptable if its not your first language IMO
The problem lies when people are just plain stupid / can't be arsed - ie chav speak.
Old Jul 26, 2007 | 03:22 PM
Boab01's Avatar
The difference is easily noticable between someone who is making an effort to write in an unfamilar language and someone who is just a muppet.
i say, string the muppets up.
