can't start the engine...
Old Jul 26, 2007 | 12:56 PM
algeusis's Avatar
Default can't start the engine...
hi
finally bought crashed s2000. but can't start the engine, starter works but that is it. got EPS indicator, error codes are 14 and 22. what's more, steering gearbox is broken, airbags exploaded. been thinking, ECU have blocked engine....
please share your thoughts
sorry for lack of knowledge
Old Jul 26, 2007 | 01:28 PM
s2konroids's Avatar
Doesnt sound to go to me if its crashed :S
I very much doubt the ECU would have of blocked the engine.
EPS - is the steering.
Check the FAQ for the codes
Ste_Nova's Avatar
aftermarket imob?
Old Jul 26, 2007 | 01:30 PM
GrittyShaker's Avatar
Originally Posted by Ste_Nova,Jul 26 2007, 10:28 PM
aftermarket imob?
I was about to post the same.
Old Jul 26, 2007 | 01:34 PM
MB's Avatar
MB
Member
I normally give a more technical response but in this case, its sounds pretty ****ed.
Old Jul 26, 2007 | 01:41 PM
Lloyd Six's Avatar
If it has nearside frontal damage have you checked the air-pump is still intact?
Could do with knowing some info on the car, year and what kind of damage etc
Old Jul 26, 2007 | 01:42 PM
MB's Avatar
MB
Member
14 Open or short to body ground in the torque sensor circuit
22 Excessive change of the vehicle speed sensor signal
----------A problem with average for vehicle speed and engine speed
Old Jul 26, 2007 | 01:43 PM
MB's Avatar
MB
Member
Won't be the airpump Lloyd - the codes dont relate and also should still start, but would give a CEL I believe...
How come you bought a wrecked one then?
Old Jul 26, 2007 | 01:46 PM
Lloyd Six's Avatar
S2000 engines sit on hydralic mounts which do give quite a bit so in a med frontal the ground wire from the N/S under chassis rail upto the engine can snap causing voltage issues across all the sensors.
Old Jul 26, 2007 | 01:47 PM
MB's Avatar
MB
Member
Yup, id go with that.
