Car missing
Old Feb 18, 2010 | 11:32 AM
barefoot's Avatar
Default Car missing
Put on a new maf sensor from hardtop guy as car was missing now and again and kangarooing. Made no difference sometimes put my foot down and it's like a big flat spot then all fine. Had the engine light on before putting new maf on but it has gone off now.
Is it a case of taking it into local stealer to have the codes read and get them to look it over or any tips before I do?
Thanks
Kev
Old Feb 18, 2010 | 11:34 AM
Itchy Dick's Avatar
S2000 doesn't have a MAF, that's your problem!!!
s2konroids's Avatar
How do you know it's definetly the map sensor? it could be the lambda sensor or plugs have a butchers on the search for symptoms.
Old Feb 18, 2010 | 12:00 PM
E4RTH WORM JIM's Avatar
......Or borrow a scan gauge or ODB II reader off someone and check the code yourself.
Cheaper than Honda charging you 80 notes.
Old Feb 18, 2010 | 12:20 PM
MB's Avatar
MB
Member
Hi BF,
Did you replace the O ring underneath the sensor?
It's easy to miss, and if you re-install without it, you will get an air leak.
Did you reset the ECU after replacing the MAP? If not the car will learn itself pretty quickly, just go out and give it some stick though the gears.
If the problem doesn't go away then it could be a number of other things. Lambda failure or valve clearances can cause misfires, as will dodgy plugs / coil packs / blocked injectors.
It would be good to know the CEL codes - you can buy your own code reader from Ebay for about £40 which is normally what the dealer charges you.
Old Feb 18, 2010 | 12:55 PM
barefoot's Avatar
Cheers guys yeah meant map sensor, obviously I did not know what the problem it was but did some searches on here and that came up the most so went that route and yes MB I did forget the o ring! I remember wondering what it was for so tomorrow that will be my 1st line of attack will post back ta.
Kev
Old Feb 19, 2010 | 08:36 AM
barefoot's Avatar
Well all seems well now the O ring is on thanks MB! It must have been the map sensor that was causing the flat spots etc and when I put the new one on without it a new problem was created similar to the original thankfully all sorted.
Old Feb 19, 2010 | 09:16 AM
mikey k's Avatar
result!
Old Feb 19, 2010 | 01:14 PM
Phil_D's Avatar
Top info from MB.....Great job
RevRanger
Jul 19, 2014 04:22 PM
TRD_Celica
Mar 3, 2011 01:09 PM
Deliverance
Aug 4, 2010 07:17 PM
S2K Type R
Sep 3, 2008 04:46 PM
hydeaway
Jul 31, 2005 02:13 PM
