car pulls to the side
Originally Posted by lower' date='Jan 9 2009, 11:45 AM
have you checked the driver's side?
If the passenger side calipers work and the drivers side are seized, the car will pull to the left.
Originally Posted by baldy2007' date='Jan 9 2009, 12:57 PM
no it pull s the same way all the time . fast or slow speed
As i said before, if they are seized and don't apply any pressure to the disc, the car will always pull to the left under braking.
Check your tyre pressure first.
Have you had any work done? This could be caused by a brake caliper that needs bleeding.
Other causes, worn out brake pads, front toe out of whack,
worn suspension components, damged spring or shock absorber.
Absolutely correct m1bjr, when I first got the S in the summer I thought it was my driving technique, thought I might have been over zelous and had been pulling at the wheel on gear change, but left hands off the wheel (I know bad idea) while accelerating on change up to see if it was me or not. So looks like full geo set up needs to be done. Will seazed geo bolts etc. be covered under an independant dealer warranty? Already had new clutch plate in, snapped drop link replaced and timing chain pre tensioner done under warrany, its been quite a good one. Do you think I'm pushiny my luck, may be worth a try.
Thanks
S
Thanks
S
