car pulls to the side
Old Jan 9, 2009 | 11:52 AM
  #21
STEVE PEARSON's Avatar
Might try luck again, if not I agree had a great run. If no luck think I will just bite the bullet and get her done.
Cheers.
Old Jan 9, 2009 | 02:06 PM
  #22
chrispayze's Avatar
I had this problem when my tyres were worn. Swapped rears around and it pulled the other way. New tyres and the problem disappeared. So, tyres (pressures or wear), suspension geometry or brakes are the most likely culprits. Start with the cheapest and work upwards in price!
Old Jan 9, 2009 | 03:32 PM
  #23
m1bjr's Avatar
True, I always assume that eveyone does the obvious, which is a bit daft of me really
Old Jan 10, 2009 | 01:35 AM
  #24
lower's Avatar
Originally Posted by STEVE PEARSON' date='Jan 9 2009, 07:56 PM
Sorry to hijack thread, but my S pulls to right on acceleration and to the left when I lift off, any ideas.
Apologies again for hijack.
Check your tyre pressures first.
This is a classic symptom of mismatch tyre pressures on the S.
If the the tyre pressure on one side is higher than the other it effectively changes the diameter of the wheel and causes the diff to do some funny things.
I have had this twice. Once when i had a puncture and the other when i had some new rear tyres and the tyre fitters had set one tyre to 32psi and the other to 38psi.
Old Jan 10, 2009 | 01:37 AM
  #25
lower's Avatar
Originally Posted by m1bjr' date='Jan 9 2009, 06:39 PM
Lower - spot on Sir!
(Our resident brake basher)
Old Jan 10, 2009 | 01:42 AM
  #26
mikey k's Avatar
Originally Posted by lower' date='Jan 9 2009, 02:50 PM
I understand that. Check the drivers side calipers too.
As i said before, if they are seized and don't apply any pressure to the disc, the car will always pull to the left under braking.
I'm with lower
Why would geo affect a car ONLY under braking
Old Jan 10, 2009 | 01:51 AM
  #27
Gaspode's Avatar
Be careful swapping tyres round.
Some tyres are directional. Could make for interesting driving in the wet.
S2Bray
Jan 8, 2018 07:13 AM
Ellandback
Car Talk - Non S2000
16
Jan 23, 2009 08:37 AM
gaddafi
Dec 13, 2004 11:09 AM
jipsom
Jun 15, 2004 08:30 AM
