Car takes time starting up after stalling
Old 06-28-2015, 07:53 AM
  #31
gbduo's Avatar
I thought the immobiliser was part of the alarm system? Because I have a AEM Series 2 and the immobiliser definitely still works.
Old 06-28-2015, 08:13 AM
  #32
flanders's Avatar
How do you know it still works, have you tried starting it with a uncoded key?
Old 06-28-2015, 08:18 AM
  #33
gbduo's Avatar
Well if I leave the car unlocked for more than a minute, the immobiliser kicks in and the car won't start till I try and unlock it again? So the alarm unit is still interrupting the signal to the starter motor and immobilising the car?
Old 06-28-2015, 09:33 AM
  #34
flanders's Avatar
Well thats probably just a feature on your alarm system then.
The factory immobilizer needs to communicate with the oem ecu to function and it does not affect the starter motor.
I usually never lock my car when it sits in the garage, starts fine every time.
Old 06-28-2015, 12:10 PM
  #35
gbduo's Avatar
Its the standard fitted alarm?
Old 06-28-2015, 11:26 PM
  #36
BenRNBP's Avatar
I think there's a different problem than the key or immobiliser here. I'm under the impression it can be a bit tricky to get the cold + hot starts calibrated properly with an aftermarket ECU. But also it could be a dodgy fuel pump relay, a crank/cam sensor issue, or any other number of things. It's just my gut on this, but I think you're barking up the wrong tree with the "poor starting = problem with the key"
Can you hear the fuel pump run for a couple of seconds when you turn the key ?
Old 06-29-2015, 02:53 AM
  #37
gbduo's Avatar
If you have an AEM I can send you my map to see if it solves it. I wouldn't use it to drive on as my engine is wildly different to yours in level of tune, but you could use it to see if the car starts earlier.
Old 07-02-2015, 03:22 AM
  #38
MB
Member
MB's Avatar
You'd have to have same size injectors and everything else for it to start. Wouldnt advise it!
Old 07-02-2015, 04:29 AM
  #39
kahn_v's Avatar
Yea I have 410cc injectors
turtlepower
06-26-2021 11:03 PM
zeroptzero
10-26-2013 12:37 PM
MandaJane
07-22-2013 11:14 AM
PwetNgManok
10-23-2012 09:32 AM
TProuty
05-15-2009 03:33 AM
Quick Reply: Car takes time starting up after stalling
