Cat woes
Cat woes
I think my cat has gone meoww for good, it rattles and when i get up on a ramp today we'll see for sure if its a heat shield or a stone thats causing it, but I doubt it.
Couple of questions -
- What do people do generally to replace? I presume main dealer is stupid money
- Trying to fund a 2nd hand one, did they change design after a certain year? My car is '99 so up to what year can I source one from?
- Decat won't pass a MOT / NCT I presume?
- Will a sports cat pass?
Any other help or advice would be greatly appreciated
1 Post
I believe that in some cases you can repair your CAT. Mine for example it rattling. It turns out one of the two elements inside mine has come loose and is hitting against the O2 sensor. it doesn't rattle all the time, but when it does you know about it.
What I have done was take the CAT off the car. Grind off the nuts holding the shielding on (these were fused together on mine). I made sure the element was in it's correct place, and measure the distance from the neck to the top of the element. I then transposed that onto the surface of the CAT to give me a rough idea of where to drill. I started with a small pilot hole just to see how close I was. My aim was to not hit the element, but get the self tappers to rest against it. My fear was that the element would break up inside the CAT
This diagram might help explain what I'm doing
Now I will admit my first attempt wasn't a 100% success. It lasted for a few days before rattling again. I think my self tappers were too short and they have "bent" back under the force of the moving element so I need to have another go. I may look at running a very long bolt from one side to the other. This would prevent the element from moving and there would be no way it could force it's way past like it has done with the self tappers.
Another option might be to break up the moving element and pour out the pieces. Be careful if you do this as your car may not pass the MoT if there is less element inside.
If my second attempt works I will start a new thread with a few photos to help other people in a similar situation.
ok, all options are good....
priced a cat from Honda - 1500 euro - about 1300stg!!
I can get one made up, new cat centre piece using the old flanges for 250euro or 220stg..... I think I might just go with this
Originally Posted by eSeM,Jul 7 2009, 08:07 AM
Either a used replacement from a breaker or a Berk Hi-Flow cat. Yes, a replacement from a dealer is silly money.
The Berk Hi-Flow cat certainly will.
