Cel code p1412
Old May 28, 2008 | 11:47 AM
RISLAR's Avatar
A snorkel wouldnt do it as you dont remove the airbox for that, but you still could have knocked the vaccume hose as it runs round the back of the airbox, i would deffo start there then the relay
Old May 28, 2008 | 12:13 PM
a3lkx's Avatar
cheers rislar ill get on to it 1st thing and keep you posted thanks
Old May 28, 2008 | 12:20 PM
GavB's Avatar
The ECU error codes are in the FAQ's. For some reason though these two codes are not on the list. Looks like they need an update...
Old May 28, 2008 | 12:21 PM
RISLAR's Avatar
No bother fella, keep us posted
Old Jun 4, 2008 | 09:10 AM
a3lkx's Avatar
hello again no joy with the vacume hoses? tried reversing the hoses that go in to the air pump and that did nothink to? tried to clear the codes via obd console and it would only clear 1 code? rescanned and only 1 code came up this time the p1412 ???
Old Jun 4, 2008 | 09:54 AM
MB's Avatar
MB
Member
Very likely to be the relay for the secondary air pump.
Old Jun 4, 2008 | 09:56 AM
RISLAR's Avatar
Did you check the relay? beat me to it !!
Old Jun 5, 2008 | 08:03 AM
a3lkx's Avatar
i sure did yes relay seems fine but can not be 100%sure of this looks good fuse is fine etc i guess i should just replace it and see?
Old Jun 5, 2008 | 08:09 AM
MB's Avatar
MB
Member
I haven't got a clue what you just said
But you won't know if a relay is buggered from looking at it externally.
Old Jun 5, 2008 | 08:25 AM
RISLAR's Avatar
Well not unless you can compare it with another one as it will usually be jammed open or closed!
