CEL light
Old Feb 6, 2008 | 01:35 PM
  #31
MB's Avatar
MB
Member
Hi Moto - you might want to shrink your signature pics a bit - looks like you have added an extra one and its stretching the page a bit. If its just me then let me know!
Crap in the tank is unlikely as there is a good size filter on the pump.
Its either the knock sensor telling you that you are using crap fuel, the filler cap thing, or jsut one of those spurious things.
Good thing is, that if it is spurious it will go away.
We are all guessing until you get the code though.
Old Feb 6, 2008 | 01:39 PM
  #32
RISLAR's Avatar
Spoke to one of my mates and he has a code reader so i'll will get it and post for future ref!! Not till sat though but thankks for for everyones input
Old Feb 6, 2008 | 01:40 PM
  #33
motogp1's Avatar
sig better ?
Do you think it was just coincidence that he had just filled up or could it have something to do with it.
Old Feb 6, 2008 | 01:47 PM
  #34
MB's Avatar
MB
Member
It probably has, hence I think it might be knock sensor related. What happens is that the ignition advance is set for a high grade fuel, then you put crap stuff in, and with the same ingition settings you get a fair bit of knock. This is picked up by the knock sensor and in extreme cases it can go into a kind of limp mode where it really backs off timing. After time it will recover and compensate, and the light goes out.
Either running the car through it, putting good fuel back in, or an ECU reset will sort it.
In this case you really do need the code before you reset.
It may be unrelated, but where there is an observed change (in this case fuel) it normally hints at the fault.
PS Signature better
Risla - have you floored it since and does it perform ok? Not suggesting you do (if it was mine I would) but just interested.
Old Feb 6, 2008 | 01:54 PM
  #35
RISLAR's Avatar
Didnt get the chance to get it into vtec! i'll give it a go though, i filled it up at BP though! and i overfilled it as i wasnt watching and it went all ovre the place!! that'll teach me!
Old Feb 6, 2008 | 01:56 PM
  #36
RISLAR's Avatar
Badger has maybe never had a full tank in it
  #37
motogp1's Avatar
Old Feb 6, 2008 | 01:58 PM
  #38
MB's Avatar
MB
Member
I'd also just open the fuel cap up and close again, now you have used some fuel.
Old Feb 6, 2008 | 02:00 PM
  #39
RISLAR's Avatar
Just done that but not had a spin, just fired her up, i should be able to tell soon though
Old Feb 6, 2008 | 03:02 PM
  #40
Badger's Avatar
Missed this one somehow.
I can categorically state that the CEL has never ever come on during my ownership and I have certainly used 95 on occassion.
I might have run out once too But that was about a year ago.
Was this after the oil flush/replace and decat? Could be the 02 sensor if the latter.
