Changed to 10w40...
I downloaded the Honda manual and it says 10w40, my car also ran quiet from when it was last serviced by Honda until I put the 5w40 in :s
10Ws are usually thicker at operating temperatures than 5Ws so it makes sense.
Bas oil viscosity (BOV) is whats key here and whilst the xW indicates the cold flow it also gives an idea of the BOV. The amount of polymer determines the Kv100 of the oil and hence its higher grade, however this is measured by seeing how long the oil takes to flow down a tube under gravity, nothing like the conditions in an engine. Often the VM is temporarily sheared down too (depends upon the type of VM used).
Base oil doesnt shear down and you can have oils varying from a 4.5 to a 6 cSt BOV that all 'look' the same. So you can see there is more to it than just reading the xW number.
In something like a TCT i think BOV is more important than either the xW number or the Kv100 and is why I wouldn't use a 0W in an S2000 engine.
