Changing calliper - handbrake cable?
I'm going to change my sticky NSR calliper today, with a very mechanically minded colleague from work.
Has anyone got any tips?
Is it straightforward to re-attach the handbrake cable?
My NSR caliper is also sticking a bit.. seems ok when its been parked up and only starts sticking if i use the handbrake while i'm out once its warmed up. Is this a handbrake problem or just sticking caliper problem?
Originally Posted by JimUK,May 23 2008, 04:21 PM
My NSR caliper is also sticking a bit.. seems ok when its been parked up and only starts sticking if I use the handbrake while i'm out once its warmed up. Is this a handbrake problem or just sticking caliper problem?
Have you Just had new pads on the rear recently?
Originally Posted by MC_BLADE,May 23 2008, 10:43 AM
Jim its your caliper, Are you certain its NSR? (by the way if you have been hammering the car you should never apply the had brake until its cooled down). Keep an eye on it the wear of the Pads + discs give big clues as to whats happening. Are you geting excessive wear ie are they catching all the time? Do you just hear them "clunck off" after you set off?
Having new pads put on tomorrow so going to get my mate to have a proper look at the rear caliper. Its definitely near side rear as can feel the heat coming off it when i stop. Although seems to be ok tonight when i've just been out..
Originally Posted by MC_BLADE,May 23 2008, 10:55 AM
Maybe just needs excercise, get him to look if the seals are ok, and the gliders are free, sometimes just winding the piston back when you change the pads helps free things up.
steve_the_greek
Apr 23, 2005 04:40 PM
