Changing car battery
So I'm thinking about having a go myself changing the battery. I've had a read of a few guides and watched a few videos. Does anybody have any top tips? I'm a little nervous it must be said because it's electrical, is there actually any real risk of getting a electric shock?
No risk at all unless you're incredibly careless. When removing the terminals, take care not to touch the spanner on anything else metallic.
Remove the black negative/earth cable first (closest to the back of the engine bay) and then the red positive cable. Refit with positive first then earth.
And don't mess around with batteries that will fail prematurely, get one from your Honda dealer, it will be a good price, last longer (it comes with a three year warranty), and you know the battery terminals will be the right way round.
Don't forget to check you have your radio code, and do the ECU reset routine when you've fitted it. If you've not got the radio code get Honda to fit it they will extract the code for you.
Yeh Yuasa would have been my second choice since I've heard nothing but good about them back when I still had my bike. But most people on here say oem is best so I just got mine from Si. Thanks for the advice guys!
Hope you get it swapped over with no bother. It's a good time to remove the battery tray and clean up in the corner. I got carried away and stripped & re-painted the tray and top clamp. Now in wrinkle black for added bay points
I just changed the battery and it was as easy as everybody said it would be, thanks guys! Now I went for a little drive so the ecu could relearn things as advised, then the cel came on. I know it won't be anything major but does this normally happen and anybody have any ideas what it might be?
