changing a diff
Old Jun 25, 2012 | 01:22 AM
s2konroids's Avatar
Default changing a diff
Hi,
How easy is it to replace a diff?
Is it a case of just loosening it off, disconnecting the prop shaft at one side and disconnecting one half shaft moving it to the side and disconnecting the other half shaft and dropping it?
How long would it take to remove one and fit one?
Cheers
Old Jun 25, 2012 | 01:33 AM
MPS2000's Avatar
http://robrobinette.com/S2000Differential.htm
That has all the info.
Old Jun 25, 2012 | 02:01 AM
razzele's Avatar
That's a good link. The props haft bolts are a pain to remove, impact equipment required and even then it's hard to get straight on the bolts.
Old Jun 25, 2012 | 02:05 AM
lovegroova's Avatar
See page 15-9 of the service manual - apparently you need a ball joint remover...
Old Jun 25, 2012 | 04:12 AM
loftust's Avatar
...a hammer and pry bar is better
Old Jun 25, 2012 | 04:23 AM
chrisr111's Avatar
You can unbolt the upper wishbone from the chassis if you don't have a ball joint splitter--not sure how much the alignement will change doing this though......
Chris.
Old Jun 25, 2012 | 05:00 AM
adz9's Avatar
I did mine twice on my yellow S and remember it being pretty easy. As it was JDM all the bolts came out easily! This might not be the case with a UK car though! I'm pretty sure the bolts on the shafts could be a right PITA on my current one.... they look rusty!
Old Jun 25, 2012 | 08:09 AM
s2konroids's Avatar
Thanks.
How long did it take you?
Old Jun 25, 2012 | 02:27 PM
Ultra_Nexus's Avatar
I tried to change Budgie's diff once. Basically, I was trying to get the hub nut off by standing on a 5ft pole and jumping.
I knew it was time to stop when you watch solid steel look like playdoh.
Otherwise, removing half shafts is best done with a mate who can turn the axle whilst you are under the car.
Old Jun 25, 2012 | 02:30 PM
razzele's Avatar
Impact gear for hub nut helps.
