checking oil.
Old Aug 8, 2007 | 02:04 PM
wang_uk's Avatar
Default checking oil.
odd one really. I noticed when i check the oil before starting the oil is on the full mark. when I check the oil when warm the oil drops an x and a bit even after 5mins but if the check the oil after 15-20 mins the oil at the top again.
Whats the deal. take the reading after when warm after 5 min or after 20mins
Kind Regards
Stefan
Old Aug 8, 2007 | 03:20 PM
aldfort's Avatar
This is not unusual.
When the engine is just turned off after running a lot of the oil is in the top end of the engine. It can take well over an hour for all of it to drain down to the sump. This is a good thing BTW.
The change of one "x" you are seeing equates to about 200ml of oil. It does not really matter if you switch off and top up after 5 mins or if you top up from cold.
However do keep checking regularly as oil consumption can vary a lot with this engine depending on several factors, not least, how much VTEC you use!
Old Aug 8, 2007 | 11:41 PM
wang_uk's Avatar
So the Best bet is to check after 15min really as i dont fancy dropping to much oil in.
Cheers
stef
Old Aug 8, 2007 | 11:51 PM
Survey S2000's Avatar
best to check once all the oil is back in the sump. i.e. "well over an hour". Try when it is cold for ease.
Old Aug 8, 2007 | 11:53 PM
Nick Graves's Avatar
Not having any oil in stops it dripping off the dipstick when you chack it.
Old Aug 9, 2007 | 12:17 AM
Pie_n_Chips's Avatar
Now now Nick, play nice
Old Aug 16, 2007 | 02:05 PM
lordjimimac's Avatar
one x = 200ml?
the tech faq says an x= 100ml, but ive been debating whether that was correct
Old Aug 16, 2007 | 02:09 PM
m1bjr's Avatar
[QUOTE=aldfort,Aug 9 2007, 12:20 AM] However do keep checking regularly as oil consumption can vary a lot with this engine depending on several factors, not least, how much VTEC you use!
s2k_Doug67
Nov 13, 2014 06:24 PM
amielo
Aug 27, 2007 09:22 AM
Mannn
Jun 1, 2004 06:22 PM
baptistsan
Mar 26, 2004 12:40 PM
Skip
Dec 2, 2003 08:03 PM
