clonk
Old Sep 7, 2014 | 08:58 AM
gbjhch9's Avatar
Default clonk
Hi GBJHCH9 here i have noticed a clonking noise from the rear of my car it will occur in reverse as well seems to be harsher the quicker you pull away, i have just replced the drop links what should i be looking for
GBJHCH9
Old Sep 7, 2014 | 12:04 PM
mikefifth's Avatar
Differential mounts
Old Sep 8, 2014 | 09:44 AM
gbjhch9's Avatar
Found that my o/s rear caliper is the culprit every time i stop then pull away it makes this metalic clonk had a look with a friend and could not see any probs. will invest in new pads let you know
GBJHCH9
Old Sep 8, 2014 | 09:51 AM
markforrester99's Avatar
GBJHCH9
Check that the caliper has all the shims in place, you should have 3. One in the caliper itself and 2 that fix into the caliper bracket. The symptom you discribe is pad rattle and it can occur with cheap aftermarket pads that are too loose fitting in the caliper bracket.
klapamos
Jan 17, 2017 02:31 PM
boyguan
Aug 9, 2012 03:36 AM
Topplayer
Jun 18, 2012 05:54 AM
Y2KS2K02780
Apr 15, 2011 08:31 AM
darkin.1
May 1, 2009 12:36 AM
