Clonk when disengaging clutch
I've recently noticed a slight clonk when I disengage the clutch to change gear - bizarrely there is no clonk when re-engaging.
Is this backlash in the diff, worn prop shaft joints or something else?
Thanks for any pointers as to where I should start my investigations.
Originally Posted by mikefifth
I had this, was an amalgamation of a propshaft that had shat nutella everywhere and a leaking diff mount.
UJ are replaceable but you can get a second hand prop for around 50 which is often cheaper and easier. Very easy to swap prop, literally 12 bolts, but be prepare to have a hacksaw as the allen heads are made of cheese, like all honda s2000 bolts
sfphinkterMC
Nov 26, 2002 05:50 AM
