Front end knock
Ok so my s2000 has a front end knock, it does not do it at speed, i can throw the car around with no noise, but low speed turns i get a knock, does not matter if left or right lock is applied, does it both ways.
Info about the car;
Ohlin coilovers - just been serviced
Brand new front mugen caster bushes
Recent Geo
New drop links.
All suspension bolts have been undone and re-tightened except the adjusters as i did not want to throw the adjustment out.
anyone have any idea what it might be?
https://www.youtube.com/watch?v=MfCI1_qbrwU
Info about the car;
Recent Geo
New drop links.
Funny, mine does the same with Ohlins on. I've been under the car a couple of times and checked everything is fully tightened up but it still does it as the OP describes.
If you have the Spherical bearing type top mounts, what's the solution, change to OEM?
Haven't checked the sub frame bolts but that was my guess, car is going for a new clutch soon, so i was waiting to see if that would sort the problem rather than having a go at tightening them myself as they will be loosened and re-torqued for the clutch.
Drop links are new and oem from hendy, i thought i might not have tightened them enough so i did go back undo them and tightened them as much as i possibly could without damaging the hex hole. Only thing the car was in the air (both sides of front) when i did tighten them, not sure if car needs to be on the ground
Car is booked in at Daytona auto's for the clutch 2nd of august, so hopefully he will be able to shed some light on it when i get their
Sounds like a bolt catching on the half shaft/prop,
its That bad !!
ABS sensor & rota
Disc & shield area,could jack one front wheel up at a time and give it a spin
Oh something else just thought of is a turret spot welds snapped.
Rack bushes/loose/worn ect..
Sub-frame bolts,as said would also be good place to start.
its That bad !!
ABS sensor & rota
