Clutch expert required
Hi guys
I'm about to tackle my first clutch replacement on the S. Are there any owners in the Mids/NW area willing to pitch in with pointers or even some elbow grease? Ray has kindly offered the use of his four poster in Congleton, but as neither of us have tackled a clutch before, it would be nice to have an expert on hand, to make the tea and point out potential pitfalls
Cheers in anticipation
Wayne
Wayne
I'm not an expert with an s2000 clutch but will happily pop along to pick up free tips for when I have to do mine...Done plenty of other clutches though on rwd cars.
I'm good at passing spanners, drinking other peoples coffee and poking things if this helps?
The prop shaft removal looks the simplest part tbh. I'm more concerned with top starter bolt removal and whether or not to drop the sub frame or if I can get enough tilt and just remove the rear gearbox mount, so I can get a bloody big extension in for the top gearbox bolts
Oh almost forgot, cheers Gaz, your more than welcome
I've done 2 of these mate, not too bad, last took me about 3 hours. Pay for my fuel and a bit of beer money and I'll help you fit it
Matt
EDIT: I don't know if you've upgraded your car at all but if so I'd really recommend a lightweight flywheel if you haven't already got one, great addition and no effort to change once the clutch is off.
Matt
Flywheel is a shout!
You need to drop the subframe 3 inches, whether or not you could undo the top 17mm bolts is up for discussion, but the box needs room to come backwards to clear the input shaft, which you wouldn't have if you don't lower the whole frame.
Oh, and the wiring going to the knock sensor can be a PITA, it's very easy to exert too much force when undoing the starter bolt and it ends up pulling the plastic part of the knock sensor off with the plug!
Without meaning to hijack Wayne's thread what difference does a lightweight flywheel make & what does it actually do?
Also, from what I have read, some places recommend changing the clutch release & pilot bearing at the same & again WFT do they do?
Matt
Matt
If I was keeping the car I'd invest in a new flywheel, but as she's going there's no point - well for me anyhow.
Cheers
Wayne
The pilot bearing is a little bearing that fits in the flywheel, the release bearing is the main bearing that operates the release plate that disengages the whole clutch.
When are you doing it Wayne?
