Clutch Query Help!
Old Oct 2, 2009 | 04:16 PM
faisal668's Avatar
Default Clutch Query Help!
Hi guys
Think my clutch or the pressure plate has gone, but not sure which one.
It happened randomly, there use to be a lot of resistance but now it seems there is none on the pedal. To get the bite point you almost have to have the clutch fully pressed. Any ideas? It's not slipping. My gear selection seems to be okay. Does it sound like the PP? Mind you I still have to check the fluid levels, but if there is a leak it should be apparent?
Thanks
Old Oct 2, 2009 | 05:09 PM
m1bjr's Avatar
If either have failed it would either not let you select, or it would slip surely?
Sounds like fluid level/air or maybe the cylinder seals are shot.
Old Oct 3, 2009 | 01:47 AM
loftust's Avatar
walter22
Jul 9, 2014 03:17 PM
nightime
Socal Swap Meet
13
Feb 3, 2010 06:58 PM
hypforlife32
Jan 28, 2010 03:45 PM
donkeykong
Jan 11, 2007 11:59 AM
DiamondDave2005
Jul 28, 2005 11:01 AM
