code readers
Old Mar 7, 2015 | 12:00 AM
westburywheeler's Avatar
Default code readers
Can any one recommend a code reader that they've brought, had a spin yesterday on track which has brought the ecl light on. Car wouldn't run right untill I went through the heart soak cycle ie tick over untill 2 activations of the cooling fans, now runs as normal, but light still on. Ihave some one who can read the code for me next week, but thought I might invest in a reader and learn more about engine managment. Any advice would be appreciated. Thanks.
Old Mar 7, 2015 | 12:10 AM
lovegroova's Avatar
A smartphone app (such as Torque https://play.google....rowl.torquefree) along with a cheap reader (bluetooth for Android, Wifi for apple) will do the job nicely.
These let you put together data logs for "exciting" track videos too.
[media]http://www.youtube.com/watch?v=ubNrDSV4tBY&hd=1[/media]
Old Mar 7, 2015 | 12:16 AM
jimmyb1978's Avatar
I've got an ultraguage which reads and resets codes. but the above has more tricks
Old Mar 7, 2015 | 03:14 AM
Old Mar 7, 2015 | 03:15 AM
Thanks LG, what blue tooth reader do you use.
Old Mar 7, 2015 | 03:16 AM
lovegroova's Avatar
That was a generic one, like this: http://www.amazon.co.uk/Maxiscan-Blu...obd2+bluetooth - there are loads and loads of options out there, some for even less money than that!
Old Mar 7, 2015 | 03:28 AM
Thanks I think ill give it a try, I fancy the blue tooth option. Can you leave it pluged in permanently ?
Old Mar 7, 2015 | 03:41 AM
lovegroova's Avatar
There is talk that they drain the battery. The more expensive ones don't apparently http://www.amazon.co.uk/427201-OBDLi...ywords=obd2+mx but they are a lot more money. It only takes 2 seconds to plug/unplug, so probably not worth it.
Old Mar 7, 2015 | 04:03 AM
So best guess at the fault code ? I was thinklng fuel related unless something broke, spin was a 180 anti clockwise at around 70mph, and didnt leave the tarmac.
Old Mar 7, 2015 | 04:05 AM
RichwiththeS2000's Avatar
Did you clutch in when you spun? Engine running backwards probably confused the heck out of some sensors..? /theory
