code readers
Old Mar 7, 2015 | 04:35 AM
lovegroova's Avatar
Originally Posted by RichwiththeS2000
Did you clutch in when you spun? Engine running backwards probably confused the heck out of some sensors..? /theory
Yep, most likely this, it's pretty common for track related spins.
Old Mar 7, 2015 | 02:01 PM
westburywheeler's Avatar
So took the car out for a spin today (-: and all seems normal, vtecs ok, but light still on.upgraded my Torque app and ordered the blue tooth reader, will let you know result, thanks for the help.
Old Mar 9, 2015 | 08:07 AM
imc27's Avatar
Can you use one of these to reset the Airbag warning light (for example) which happened to come on yesterday after some idiot (for example) removed the fuse because he wanted to (for example) use an "add a circuit" thingy to instal a dash camera?
Speaking hypothetically, obviously.
Old Mar 9, 2015 | 08:53 AM
MJK46's Avatar
With the airbag/SRS light, try this:
http://nvsaudionj.blogspot.co.uk/201...=1333200608040
Has worked for me in the past!
Old Mar 9, 2015 | 10:04 AM
imc27's Avatar
Thanks, I'll give that a try. How do people find out about "fixes" like this?? It's not exactly "Control-Alt-Delete" is it?
Old Mar 9, 2015 | 12:37 PM
RichwiththeS2000's Avatar
Somewhere there is a lab full of people poking paper clips into things to see what happens..!
Old Mar 9, 2015 | 02:30 PM
Trunkz's Avatar
Bear in mind these apps dont work on a custom ECU (AEM / Motec etc..)
Old Mar 9, 2015 | 11:38 PM
Toms1989's Avatar
I use a knock off of a scan gauge. Called Turbo gauge. Monitors coolant temps, air intake temps and a lot more stats on the car and also does diagnostic trouble codes too.
Old Mar 10, 2015 | 05:22 AM
not4s4l3's Avatar
Yep, you can delete a code successfully!
However, if the problem persists it will still throw an error!
If the issue is properly fixed, it will be gone forever!
I'm using the torque app as suggested by lovergroova above together with this OBD reader from Amazon:
http://www.amazon.co.uk/gp/product/B...rch_detailpage
Torque app + OBD II reader they are about a tenner, great investment if you ask me!
Old Mar 10, 2015 | 09:16 AM
imc27's Avatar
Thanks for the replies and advice - I've ordered the reader recommended above - at that price it would be rude not to.
As luck would have it I was near to the non-franchised dealer I bought the car from, so I went in and told the very helpful service manager that my airbag warning light had come on, and he very kindly plugged in his OBD reader and sorted it out for me.
cheddaboy
Mar 18, 2016 06:55 PM
topcat7111
Sep 24, 2009 04:39 PM
ZDan
Jun 11, 2009 06:26 AM
GaryB
Apr 24, 2009 10:34 AM
a_zepeda926
Jan 30, 2009 05:17 PM
