Coilover set up front/rear
Flat floor will only increase your downforce if you can prevent air leaking in from the side as the pressure drops.
Forget aero, at S2000 level, it'll be all about weight transfer and balance!
Less rake = more understeer, less oversteer
More rake = less understeer, more oversteer
and IMO changes in rake do make a noticeable difference.
My car currently has 5 mm of rake, which has made it feel 'less pointy' and a bit like it's dragging its arse around IYKWIM, compared to when it had 10 mm of rake.
Chris.
It is quite feasible to setup the car with neutral rake and not suffer untoward effects, provided the rear toe is setup accordingly.
I had this on my S and it accelerated, stopped and handled extremely well.
Syncmaster
Jun 23, 2015 10:15 AM
sep900
Apr 2, 2009 04:08 PM
