cold nuts
Aluminium might crack if you an get enoug heat into it to change the crystaline structure but its unlikely. plus you'll melt all the paint on the alloy in the process.
ITs a nice soft metal, so if you can split enough of it and then drive a screwdriver between it you might be able to crack it that way and almost tear the bolt apart.
ally doesn't like being bent without heat. if you cold forge it and just bend a strip of it over a former it will usually tear at the rear.
if you split one side, it should be enough to loosen its grip and then you might beable to twist it off. if not your going to need to try and do the other side of it and split the whole thing in half.
This process does put your alloy at risk. you may end up scuffing the insode ofthesocket hole if the screw driver jumps.
actually the safest bet would be to drill out the wheel stud
Drill a 3mm hole as close to the center of the stud as possible. Then move up to a 6/7mm, then a 10mm. Be careful not to drill into the wheel. Chisel out the remaining parts, then remove the wheel, pop out the remainder of the stud, and install a new stud and nut.
Chris.
Not sure if there is enough material left but Irwins Bolt Grip may be an option:-
Irwins
Found these to be invaluable when dealing with rounded nuts and bolts while restoring my old 91 CRX, the more you tighten them the more they bite in!
Irwins
