Compression test results
Old Oct 19, 2013 | 03:23 PM
Aydon's Avatar
Default Compression test results
Done a compression test today on the S and got results of just under 200 on each cylinder something like 190,195,196,190 however I've realised after reading a bit on here that you are supposed to hold the throttle pedal down while cranking the engine, which I didn't - does this make my results void or do you still think its ok?
I was suspecting a HG failure that's the reason for the test and all cylinders have come back consistent so I'm guessing and hoping I am fine.
Cheers for taking the time to read this and please share comment.
Aydon
Old Oct 19, 2013 | 04:29 PM
Ultra_Nexus's Avatar
Yes, hold your throttle pedal down!
Old Oct 19, 2013 | 11:05 PM
Bandit_287's Avatar
To be fair compression test results are more about consistency. Yours are so nothing wrong there, if they were all abnormally low or high then there is an issue. What difference does it make if you hold the throttle open?
Old Oct 20, 2013 | 01:20 AM
gbduo's Avatar
You are compressing air in the cylinder.
Old Oct 22, 2013 | 01:39 AM
Irish TuneR's Avatar
Im not sure about the procedure but you should probably re do it. Also you might still have a HG gone but it might not show on a compression test if its the wrong side....
Old Oct 22, 2013 | 02:30 AM
Aydon's Avatar
what do you mean on the wrong side?
I done compression test on all four cylinders
Old Oct 22, 2013 | 03:07 AM
loftust's Avatar
A sniffer test is more reliable for HG failure.
Sent from my GT-I9300 using Tapatalk 2
adz9's Avatar
Numbers sound good to me mate. As said its consistency that matters. I had one S with consistent 185-190 on each cylinder and one, with a lower mileage engine cranking at 215 on three cylinders and 190 on one cylinder.
The 185 engine is still going strong and has been around the Nurburgring plenty of times (its now Dixon's track car). The bottom end went on the other one.....
This may be pure chance but from now on I'd definitely go with consistency over the number.
jdblood202
Aug 9, 2014 06:43 PM
s2kneub
Apr 30, 2013 11:25 PM
Moddiction
Jun 20, 2008 08:53 AM
mxt_77
Jul 19, 2004 08:26 PM
