Coolant?
Old Aug 4, 2004 | 12:01 PM
Blitzspear's Avatar
Default Coolant?
Evening all,
just wondered what coolant I should put in?
Honda Coolant?
Best stuff from local garage?
Second question. Should my new engine with 500miles on the clock be low on coolant at this stage? Would a new engine need topping up so soon? I did notice when picking the S up after having it's new engine fitted that the level was between the Min and Max but was below halfway.
Going to call the garage first thing in the morning anyway not that I'm paranoid after my last mishap!
Old Aug 4, 2004 | 12:06 PM
Turtle's Avatar
If you're just topping up a little, just use distilled water. You're not going to dilute the coolant to any signifcant amount with a little top up.
That said, with 500 miles on the clock after an engine change, I'd suspect there's a minor leak somewhere. I wouldn't expect to have to add anything.
-Brian.
Old Aug 4, 2004 | 12:25 PM
Blitzspear's Avatar
That's what I was suspecting, thanks Brian.
I THink I'll call the garage.
Old Aug 4, 2004 | 12:28 PM
Blitzspear's Avatar
If you went for a drive approx 50 miles, came back, checked coolant level and checked again 2 days later should it have gone down? Engine was still hot on first check.
Thanks.
Old Aug 4, 2004 | 01:39 PM
Amuse Boy's Avatar
I think they must have not filled it up correctly. They should have refilled the coolant and allowed the fan to go through two cycles.
Old Aug 4, 2004 | 01:45 PM
robs_silver_s2k's Avatar
Blitzspeed : I reckon that the hot test was a false reading as it will have expanded.
On the 500 mile issue it could have been an airlock. Mine also dropped a bit when the garage replaced mine and they gave me the bit that has left over to top up if required. After about a week or two I checked it again and it had dropped a little topped it up and it hasn't moved since.
Old Aug 4, 2004 | 11:52 PM
lower's Avatar
you've worried me know. i've been checking my oil religiously since my engine was replaced, but didn't think to check the coolant. a job for lunchtime i think.
Old Aug 5, 2004 | 12:16 AM
Blitzspear's Avatar
Sorry to start the paranoia off for us Lower!
Thanks for the advice as usual guys!
My oil level hasn't budged from Max yet. What Oil are you topping up with Lower?
Old Aug 5, 2004 | 12:18 AM
Turtle's Avatar
You need to compare with the engine cold.
It could be an airlock, but that'd be very sloppy work - the cooling system on a UK S is very easy to bleed.
-Brian.
Old Aug 5, 2004 | 01:30 AM
Blitzspear's Avatar
Cheers Brian!
