Crankshaft positioning wheel differences + photos
Old Apr 11, 2011 | 12:24 PM
rob2.2's Avatar
Banned
Default Crankshaft positioning wheel differences + photos
not sure if people wanna know but there are a few really important differences between early throttle body engines and drive by wire engines
one of the main ones is the crankshaft positioning wheel on the crankshaft,
you have to take the timing cover off to get to it,
Made a Tool to remove end pulley that worked a treat
then had to loosen all the sump bolts to remove pressure from the timing cover, remove the serpentine belt tensioner to get to the wheel.
throttle body engine wheel:
drive by wire engine wheel:
notice how much smaller the lugs are and there are more of them,
both wheels together:
Old Apr 11, 2011 | 12:33 PM
lucky77's Avatar
Glad you got it worked out in the end
Old Apr 11, 2011 | 01:07 PM
unclefester's Avatar
Like that Rob ... proper mans tool
Old Apr 11, 2011 | 01:13 PM
rob2.2's Avatar
Banned
cheers mate,
people on here said its a real struggle to undo the bolt so the longer the bar the less effort involved
It was so easy to undo using this MAN size tool
bruthaboost
Feb 24, 2014 07:48 AM
S2KAYYY
May 19, 2007 06:58 AM
speeeding
May 18, 2003 10:48 PM
QT_S2K
Mar 11, 2003 03:02 PM
