Dent removal
#21
#26
UK Moderator
You will need the following (I'm sure others will add anything I've forgotten):
- Jack
- Jack stands (use these, do not work under a car using a jack only)
- Wheel chocks
- 12mm, 17mm and 19mm spanners/sockets (get a set of spanners and a socket set)
- Brake cleaner
- Wire brushes
- Ceratec or similar for the shims
- Silicone lube to squirt into the piston rubbers
- Red rubber grease for the rubber boots
- Piston windback tool for rears - something like this:
- Piston pushback tool for the fronts - something like this:
- I'd recommend a torque wrench for the wheel nuts, though this is not essential.
