Differences with Japanese Import S2000?
Old 02-01-2016, 02:28 AM
MarcS2000's Avatar
Default Differences with Japanese Import S2000?
Hi there. Are there any differences between pre-facelift Japanese imported S2000's and regular UKDM S2000's?
I ask as i have purchased a rear end damaged red 1999. All of the VIN plates were removed and copart have the vin as AP11002145 which is what is stamped on the bulkhead. With the registration number I have found VIN number GHMAP1F20C1002170. The sunvisors have japanese warning stickers on them so am I right to assume this is a Japanese imported car?
Old 02-01-2016, 07:26 AM
energetic's Avatar
Does this help?
https://www.s2ki.com/s2000/topic/582...nda-s2000-vin/
http://www.vindecoderz.com/EN/Honda/S2000
Old 02-01-2016, 07:37 AM
MarcS2000's Avatar
honestly, not particularly.
Old 02-01-2016, 08:12 AM
UK Moderator
lovegroova's Avatar
These may help with regards to the differences (it's amazing what a search of the site will turn up)
https://www.s2ki.com/s2000/topic/237...c-uk-vs-japan/
https://www.s2ki.com/s2000/topic/639739-uk-vs-jdm/
Lings site give the VIN no range of UK cars as JHMAP1120YTY000001-YT999999
Did you mean to type the VIN number beginning with a J, and not a G?
Old 02-02-2016, 12:48 AM
MarcS2000's Avatar
That is what i was told by copart, i had a bit of a fight to get the vin number from them. Because it was a catagory B car they remove the VIN numbers and that is what they told me the VIN number was, I asked if it was G for Golf or J for Juliet but they were adamant it was a G.
Thanks for those links, much appreciated
Old 02-02-2016, 12:56 AM
MarcS2000's Avatar
From what I can tell it definitely seems to be an Import. It's got no washer jets, no factory fitted alarm, Japanese writing on sunvisors
Old 02-02-2016, 01:09 AM
Irish TuneR's Avatar
My JDM has the stamp on the chassis which is the same number on the plate. The UKDM ones i've had are the same but in the format lovegroova mentions above so you have a JDM chassis anyway.
Old 02-02-2016, 01:17 AM
MarcS2000's Avatar
Can you tell me where on the chassis it is stamped? all the VIN plates have been removed and I can't find anything else
Old 02-02-2016, 01:22 AM
Lankan's Avatar
Does the following help?
[attachment=90538:VIN & Engine No locations in engine bay (EU).gif]
Attached Thumbnails Differences with Japanese Import S2000?-vin-engine-no-locations-engine-bay-eu-.gif
Old 02-02-2016, 01:24 AM
MarcS2000's Avatar
Originally Posted by Lankan
Originally Posted by MarcS2000' timestamp='1454408246' post='23869072
[quote name='Irish TuneR' timestamp='1454407777' post='23869070']
[/quote]
All that is stamped on the bulkhead in that location is "AP11002145". The plate on the slam panel has been removed
Quick Reply: Differences with Japanese Import S2000?
