ding
i've picked up a smallish dent on the rear wing. you can't get behind it to push it out, so, for honda to do the work they want to take the wing off, beat it out and refit the wing (~
[QUOTE]Originally posted by sgrant
[B]i've picked up a smallish dent on the rear wing. you can't get behind it to push it out, so, for honda to do the work they want to take the wing off, beat it out and refit the wing (~
ok, it's directly above the wheel, just above the crease that runs from the rear light cluster across the top of the doors. So it's high up.
my honda garage (marshalls, reading, definately reasonable people - see the dealer survey
) took a look and said it was a big job, because you can't get behind it from under the wheel arch. Apparently they had a similar case a while back and quoted the chap "a fortune" to get it fixed.
I must admit, i hadn't thought of looking to see if it is accessible from inside the boot, although I doubt that it is; i'll take a look this evening.
Alex; that sounds like a good deal. Did they need to get behind the dent, or could they pull it from above? Sadly mine is silver, but i'm prepared for them to have a go for
) took a look and said it was a big job, because you can't get behind it from under the wheel arch. Apparently they had a similar case a while back and quoted the chap "a fortune" to get it fixed.I must admit, i hadn't thought of looking to see if it is accessible from inside the boot, although I doubt that it is; i'll take a look this evening.
