Disconnecting and charging the battery...
I'm thinking about doing this as I've borrowed a charger - was going to take out the battery and charge in indoors then reconnect.
Question is, will this cause problems? The radio code shouldn't be a problem as I've fitted an aftermarket system. But is there anything else I need to know?
By the way I want to try this since the battery is fairly new (less than 2 years), I probably drained it by leaving the door open for 15 minutes or so with the light on and now the alarm goes on when I start the car.
Thanks Chris
Thanks Chris
Just leave it in the car, but make sure the location is reasonably well ventilated as the charging - charging causes explosive gas to be produced. Not a good idea to do it in the house if you don't have a garage.
Just have the fob close to hand when you reconnect the battery. Been caught out a couple of times with the alarm going off and having to dig around to get the keys out of a pocket.
so you guy don't disconnect the cables from the battery before charging it?
I've been taking it out but the alarm beeps (disconnected beep, not alarm sounding)
I didn't want battery acid all over the place!
My 911 is permanently connected to a charger/conditioner (as the battery seems to be shit at holding a charge if it's not used regularly) and I just run the crocodile clips to the battery then close the bonnet lid on it. I haven't had any problems.
Charging in place will only work, of course, if you have a mains socket in your garage!
(FWIW, I had assumed I would need to remove it to charge it before I posted about my problem on another forum and was told that it was fine to charge it while still connected.)
