Drop Straight in to 6th!
Originally Posted by Amuse Boy,Jul 20 2005, 07:14 PM
Do not skip gears...not a good idea.
It's not about the bearbox knowing what gear you were in but the fact that the synchros are worked a lot harder when matching gear speeds - there was a huge debate on this very issue in `Under the Hood` and the conclusion was to avoid it as it will bugger the bearbox in the long term.
Feck that, I'm not changing my driving style in case the Gearbox goes 10 years down the line.
Still disagree though. I can understand that logic if you're forcing the gears at high accelerations, but a simple slot from 4th to 6th under low loading ain't gonna put the synchros under any heavier a pressure IMO.
Originally Posted by GTFCTIM,Jul 20 2005, 04:44 PM
Ask him if he can show you one of these stickers.
It's not about the gearbox knowing what gear you were in but the fact that the synchros are worked a lot harder when matching gear speeds
Shouldn't be any problem at all.
Which do you think puts the most wear on the car components:
Accelerating to 60mph in 1st and 2nd, and putting the car into 6th prior to cruising, or
Accelerating to 60mph in 1st and 2nd, and then putting the car into 3rd, then 4th, then 5th, then 6th.
