Ebay OEM Cat
Old Jul 26, 2013 | 09:02 AM
shortsoundman's Avatar
Default Ebay OEM Cat
So all i've done since starting my S2000 ownership 3 months ago seems to be fixing annoying problems. My car clearly hadn't spent alot of time in the Vtec zone before my ownership so now the CAT has developed a death rattle.
The advise seems to be to get a Berk HFC @ around £260, but can anyone tell me if the patent part CAT's on ebay are any good ?
http://www.ebay.co.uk/itm/91006H-CAT...-/190787731603
http://www.ebay.co.uk/itm/CATALYTIC-...-/190708090643
I'm not trying to be tight about it, but I don't need a HFC for the power, just as a replacement for OEM.
Old Jul 26, 2013 | 11:18 AM
Bandit_287's Avatar
Check the bolts on the cat heat shield haven't rusted and fallen out. Very common problem and cheap and simple fix.
Old Jul 26, 2013 | 12:16 PM
s2konroids's Avatar
Just get a second hand one, they won't fit properly imo and they are an unknown quality. My last one covered over 100k.
Old Jul 26, 2013 | 12:18 PM
Carl Bourbon's Avatar
I had a death rattle cat too, turns out it was missing two bolts.
Lift the car up and have a look, could save yourself a lot of money!
Old Jul 27, 2013 | 01:27 AM
Had the car over a pit at work, all the bolts seem tight (what size are they? So much rust I couldn't get any socket on them)
Given it a bang with a rubber hammer a few time and you can hear it rattling inside
Old Jul 27, 2013 | 07:54 AM
Daytona-Dave's Avatar
If your heat shields are not causing the rattle, then I would go OEM S/H or Berk hi-flow, i'm pretty sure that the OEM is a hi flow any way, I would not buy the one's you listed as the mating flange that fasten's to the manifold is incorrect, there was a thread where someone had a cracked down pipe because of this, plus they need to flow correctly
Old Jul 28, 2013 | 01:59 AM
Well the BERK HFC isn't all that much more expensive than a used OEM Cat so rather than taking a chance on the unknown quality of a used item I might as well spend £100 more and get a new quality item.
On that note, who can flog me a 63mm Berk for the cheapest price ?
Cheers/
R5HKK
Sep 23, 2015 09:44 AM
Childsy
Apr 13, 2015 12:32 AM
mobile chicane
Jan 13, 2012 04:58 AM
