ECU issues after battery replacement
Old Jan 20, 2007 | 07:02 AM
CiderBoy's Avatar
Default ECU issues after battery replacement
I took my first steps along the road to becoming a mechanical guru by replacing my battery this afternoon.
I've now noticed that the engine is struggling to find idle quickly.
If I blip the throttle the engine revs drop so low the engine almost cuts out before it finds the correct idle revs.
Does the ECU have to re-learn what it knew before?
How long will this take?
Cheers
Nick
Old Jan 20, 2007 | 07:10 AM
eSeM's Avatar
Yes! and not sure exactly.
Old Jan 20, 2007 | 07:15 AM
CiderBoy's Avatar
Thanks!
I hope my ECU is a fast learner, however first signs are that it's the class dunce.
Old Jan 20, 2007 | 07:24 AM
jimpom23's Avatar
Will take 1/2 hour to an hour of driving to sort itself out - recharged mine after it went flat and it did the same
Old Jan 20, 2007 | 07:25 AM
Amuse Boy's Avatar
Do a search for the idle learn process.
Old Jan 20, 2007 | 07:43 AM
CiderBoy's Avatar
Thanks. Have found it and will go through the process tomorrow morning.
Old Jan 20, 2007 | 08:42 AM
Amuse Boy's Avatar
easy when you know how.
Old Jan 20, 2007 | 09:57 AM
mikey k's Avatar
I was just about to post that!
Old Jan 20, 2007 | 10:01 AM
CiderBoy's Avatar
I'm surprised that you know about it Mikey.
I thought your approach to a flat battery was to go buy a new S.
Old Jan 20, 2007 | 10:11 AM
mikey k's Avatar
I have had to disconnect the S battery a few times with my history of mods!
