ECU Reader
Old Jan 12, 2007 | 07:45 AM
MunkeyBoy's Avatar
Originally Posted by Bibbs,Jan 12 2007, 04:42 PM
With the paperclip?
You earth that pin, and turn the key to IGN, and the engine light flashes.
You count how many, and then look it up in the FAQ.
ah ha!!
I'll give that a go. I'm in Caversham, so just across the river.
Old Jan 12, 2007 | 08:00 AM
Bibbs's Avatar
Undo the kneepad thing on the center console, on the side of the CD cubbyhole. It's one screw and there is a big shiny earth bolt under it.
Jam a paperclip into the end two pins (1 and 9) and then loop a wire from it to the earth bolt. Then twist the key (don't start).
The ECL light will flash periodically. Count the number of quicks and slows and then look up that number in the FAQ.
Old Jan 12, 2007 | 08:25 AM
mzm70's Avatar
I have a reader, work in Basingstoke, live in Uxbridge, still at work ATM
17:30
Old Jan 12, 2007 | 08:40 AM
MunkeyBoy's Avatar
ahhh...the two end pins. I just had the clip in 9.
I'll go and try again.
Old Jan 12, 2007 | 08:54 AM
MunkeyBoy's Avatar
Nope, no luck, no flashing engine management light after trying the paperclip fix.
If I reset the ECU by pulling and replacing the appropriate fuse, I would assume the system will still warn if it encounters the fault again?
Old Jan 12, 2007 | 09:10 AM
Bibbs's Avatar
yup, the error is cleared, and will light the ECL on reoccurance.
Old Jan 12, 2007 | 09:14 AM
MunkeyBoy's Avatar
Cool, thanks again Bibs. I'll take it for a spin now and see what happens.
Old Jan 13, 2007 | 06:32 AM
AquilaEagle's Avatar
Administrator
Doug I have a reader! I could pop over at some point if need be? or you pop here I am J17 of M25
Old Jan 14, 2007 | 09:55 AM
MB's Avatar
MB
Member
Would have suggested the paperclip but it rarely seems to work!
MB
Old Jan 15, 2007 | 12:00 AM
Bibbs's Avatar
MB
Mine is a MY00 and an Import .. so I can't tell you which is the bit that makes it work. But it defo does for me.
