EML after Air Pump Delete Kit
Hi Guys & Gals,
I've recently installed an air pump delete kit that came with my brake cooling kit. I have installed it following a guide on here and all seem'd to be fine. But the EML light come on and is throwing up P1412. I have double checked everything and it seems ok, could it be a faulty resistor?
This is how i have wired it, which seems to be the same on the guide. So thought id double check it.
Hi Guys & Gals,
I looks like the resistor is connected correctly, it should not be connected to the chassis like suggested above.
Your problems seems to be that you have disconnected the relay thing?
In this picture you will see the stuff that you need to keep.
Unrelated but I just bought the air pump delete kit aswell. Did you have to remove the bumper as suggested to fit it or can it be done pulling back the wheel arch liner?
That be it then. I have thrown that away as well. I'll have to try buy another. Thanks mate, appreciated.
Is it normal that after fitting this kit that you can get a slight smell of petrol inside the car when starting the car from cold? I fitted it two weeks ago but the last two morning (that have been the coldest since fitting it) I have smelt petrol in the car when sat in traffic a few minutes into my drive to work.
I'll get a slight rich smell from the exhaust when I reverse out my drive, but I got that before I fitted my delete kit too.
A couple of people have had broken injectors recently and their first symptom was a strong petrol smell in the cabin, might be worth visually checking them to see if you've got a leak.
