Engine failure - costs?
Old Jun 8, 2011 | 04:54 AM
  #21
lovegroova's Avatar
The chain may well last longer than my 100k miles - I intend to keep the car longer term so it makes a bit more sense for me to change it, rather than keep on replacing TCTs annually at £150 a time (you can get them cheaper of course from the USA - mine worked out at £75 as I bought a few other parts at the same time.).
£1k is on the high side of what it might cost.
The parts should be around £200, and then it's down to labour/ancilliary costs - it might be worth asking Rob at Garage-R for a price.
There are plenty of cars still going strong at 120k miles-plus who haven't had the chain changed.
Look at it this way, it's probably a similar cost to replacing the roof.
Given the amounts people spend on putting new wheels, intakes, exhausts, coilovers and other largely un-necessary items, a few hundred for the timing chain replacement doesn't seem such bad value after all.
Old Jun 8, 2011 | 05:06 AM
  #22
nickrg3.1's Avatar
Incredible how little oil it used, especially with your Italy trip.
During my 3k trip down to Tuscany I went through nearly 3 litres lol!
Old Jun 8, 2011 | 04:20 PM
  #23
TommyS2000's Avatar
Just dont understand how it took 6 1/2 hours Mr Groova!
£200 for parts is nothing. If you do get a chance would you please point me in the direction of the exact parts needed. I may be able to get a friend of mine to fit it for a much cheaper price than that!
Old Jun 8, 2011 | 11:09 PM
  #24
lovegroova's Avatar
For costs and a supplier, please see post #14 in this thread - why do I bother?
It is a lot of work - it's several pages of the service manual - 6-15 to 6-24 should give you an idea of what's involved. Lots of bits, including the water pump, alternator, sump have to be removed and replaced, valve clearances need to be redone - see the service manual for details - I think I've already mentioned it in the thread linked to in post #14.
IIRC, TGM quoted £400 plus bits-n-bobs to do the work, so it's definitely justified in terms of time taken.
Old Jun 8, 2011 | 11:25 PM
  #25
richmc's Avatar
Originally Posted by gbduo
In fact, unless the con rod broke or the spark plug was the wrong type, how can a piston hit a spark plug!?
Valves I can understand, but spark plug!?
Elastic con-rods, only way.
Old Jun 9, 2011 | 05:09 AM
  #26
Dembo's Avatar
If you do some searching on engine failures, virtually none were caused by timing chain failures (I'm special it seems), and quite a few were user error (i.e. low on oil/ignoring overheating/overreving). There's nothing to suggest timing chains are ticking timebombs, and all the evidence suggests that they nearly always outlast the rest of the engine.
About the only symptom of mine (apart from not running) was that the AA man couldn't get one of the spark plugs out. But that was after major internal badness.
Old Jun 9, 2011 | 05:23 AM
  #27
lower's Avatar
Originally Posted by matt404
Quick update...
Had a call from ABP saying they have had a quick look and it seems that the piston(s) have definately contacted a spark plug(s)! Not to sure if they just removed a plug and came to that conclusion or actually took the head off but im heading over there this afternoon so should be able to get a proper update.
More likely that its dropped a valve, the valve head has been hit by a piston and been knocked off and the valve head has been floating around inside the bore.
That happened to me on my first S. Spark plug looked like it had been hit by a piston but when the head was off you could see all the damage had been caused by the valve head bouncing around.
Its not uncommon for this to happen if the engine has been overreved at some point in its life.
Either way, the head and the block are know f*cked and you need to start looking for a replacement whole engine.
Old Jun 9, 2011 | 08:17 AM
  #28
Lilacalicat's Avatar
I was planning to take this to ABP motorsport in Crewe but after reading some reviews i think I might try to get it to TDI-north if possible.
Are you sorted now? I'm only asking because if you were planning on taking it to ABP in Crewe, are you aware that Vtecdirect have a garage/unit in Winsford??
Hope you can get it sorted
Old Jun 9, 2011 | 11:13 PM
  #29
Bassoctopus's Avatar
Vtecdirect Andy's a good guy and looks after Honda enthusiasts.
Old Jun 14, 2011 | 11:23 AM
  #30
matt404's Avatar
Thanks for all the advice guys. Not much has happened as I have only just got back from Le Mans (in a Meriva hire car courtesy of the breakdown people).
The car is still at ABP where they have looked into each cylinder to find that the damage is contained to cylinder 2 and it appears to be that a valve has hit the spark plug and not the piston (phew). They havent taken the head off to havea full inspection as I think that I will be doing this myself to determine the state of the internals.
I have just spoken to TDI-north and it seems that its going to cost me £750 in labour to replace the engine, then about £2000 for a used engine. The dielema is it financially viable to spend approx. 2750 on a car that I was intending to sell and can proabably only get £4500 for it?
Does anyone know how much the car would be worth as a non-runner for someone that wanted a project?
Its upsetting because the car is nearly imaculate (obviously appart from the engine).
