Engine flush?
Old Apr 7, 2006 | 11:31 AM
simonprelude's Avatar
If you have trouble undoing a filter then stap it with a long scredriver.
I never use a tool on the oil filters, they should only be done up hand tight, so should also undo by hand.
As Mr Spoon said, NEVER use engine flush, it removes the deposits that have built up to seal the engine.
If you are concerned about getting all the crap out then do an oil change with cheap oil (good spec still) then a couple of hundred miles later do another change with decent oil.
I do mine every 3000 miles anyway so the oil generally stays clean.
Old Apr 7, 2006 | 01:23 PM
Rusty82's Avatar
okay so stay well away from engine flushes lol.
i tend to avoid the stab with screwdriver idea, thats usually the last resort. the chain tool usually works very well... well did in the old pug but now come to the s its bit difficult! should of picked up my other oil filter remover but i didnt at time! learn to next time though.
as to only being done hand tight.... i know but i'be only had the s a month now so its an inherited problem that i guess the last honda service did.
even after 3k/3 months miles it tends to be some what black!
Old Apr 7, 2006 | 01:48 PM
Never had to do it personally, changing the filter on the teg was a nightmare, especially with the ITB's in the way
Old Apr 7, 2006 | 01:59 PM
AquilaEagle's Avatar
Administrator
Wear marigolds, they give great grip on the oil filter
Old Apr 7, 2006 | 02:12 PM
I tend to use hospital latex gloves, same effect, just disposable.
Old Apr 7, 2006 | 02:57 PM
Administrator
not as sexy as marigolds though
Old Apr 7, 2006 | 10:55 PM
Depends what colour Marigolds
Think about it,
Old Apr 7, 2006 | 11:26 PM
Rusty82's Avatar
ended up tearing the pair of surgical gloves!!!
Old Apr 7, 2006 | 11:32 PM
neil955's Avatar
i change my oil every 4.5k miles. filter normally comes off no problems. have a long cup of tea whilst the oil drains out.
just remember when putting the filter on, place a bit of oil on the new seal and then handtighten only.
Old Apr 7, 2006 | 11:54 PM
Shopman's Avatar
Does anyone use the magnetic drain plugs I have seen for sale on eBay?
My old Honda m/cycle used to have one as standard, always had a mush of filings on it!
