engine issue maybe
Old May 5, 2008 | 12:12 AM
nashby's Avatar
Default engine issue maybe
My engine when you start it from cold rattles for a second and it sounds a bit camy if anyone knows what i mean, its done 41,000 miles now with full history, engine oil is always kept very clean. is this normal?
Old May 5, 2008 | 12:13 AM
motogp1's Avatar
tct
injectors
oil type
just a few thinks to check
Old May 5, 2008 | 12:14 AM
AquilaEagle's Avatar
Administrator
Timing Chain Tensioner maybe.
Check Valve Clearances too
Old May 5, 2008 | 12:20 AM
nashby's Avatar
its had a new tct, oil is mobil 1, it has always done it from the day i bought it 32,000 miles, it also when cold rattles at about 3500 - 5000 ish, when i say cold i mean with 2 temp bars on the dash but it doesn't do it when its hot, it's not injector noise it is more a valve or cam sort of noise
Old May 5, 2008 | 12:22 AM
Administrator
When you say rattle, do you mean like a tappetty noise?
That could be valve clearances.
Old May 5, 2008 | 12:23 AM
motogp1's Avatar
My engine note changed considerably after having valve clearance done .
Old May 5, 2008 | 12:25 AM
j8mie's Avatar
Rich, how much did Honda charge for checking and changing your valve clearances?
Old May 5, 2008 | 12:28 AM
motogp1's Avatar
Hi jamie. i had it done as apart of the 54k service (actual mileage was 51k).
The engine tone changes alot its a much deeper tone now , this is what makes me think this is what the op's problem is.
Old May 5, 2008 | 12:33 AM
nashby's Avatar
yes its a rattly noise, will have honda do valves or is it fairly easy to do ones self, nothing special in there is there? should they be done hot or cold?
Old May 5, 2008 | 12:37 AM
j8mie's Avatar
Cheers Rich.
My 54k service is early next year, so I might get that checked a bit sooner. Have you noticed any drop in oil consumption as well since the valve clearances were done?
