Engine light On
Old Jan 27, 2010 | 11:08 AM
AlexMeineck's Avatar
Default Engine light On
Hi Guys
I have been reeding through the FAQ and just want your views on what might be wrong with my car.
I had the clutch replaced today which is amazing, its like a new car, anyway, the engine light came on when leaving the garage, couldnt go back as they closed when i left.
When pulling up to a stop, the car drops its revs down to 200 and it almost stalls but recovers. I have reset the ECU by disconecting the battery for 10 mins, the light went out when i started the car but got over 5,000 rpm and it came back on. i have checked the throttle cable and thats perfect.
Any ideas?
Old Jan 27, 2010 | 01:13 PM
BSM139's Avatar
UK Moderator
Not an expert, but it could be some kind of sensor has been damaged / removed when you had the clutch changed.
Hopefully someone more knowledgeable will be along to assist.
Bharat
Old Jan 27, 2010 | 01:47 PM
MB's Avatar
MB
Member
Alex, it's quite common that the knock sensor gets damaged when doing a clutch change.
You are welcome to pop it round mine at the weekend for diagnosis. I have a code reader. However, Honda (or whoever fitted it) should do it free given it's likely to be their fault.
Old Jan 27, 2010 | 02:14 PM
Oh thanks, im going to get it back their tomorrow. I will mention that to them and let you know what it was.
Old Jan 27, 2010 | 02:24 PM
MB's Avatar
MB
Member
They could also have bashed the lambda sensor, or not fitted the exhaust right - both would cause stalling. As would leaving a vah hose off (just did a search and found a couple of people have had that!)
But getting the CEL code will tell you.
Old Jan 28, 2010 | 01:29 AM
Ultra_Nexus's Avatar
I'd have gone with Lambda sensor - primary only though as the secondry one wouldn't cause the car to stall.
But as Mark says, code reader will have you sorted.
Good luck with the garage - they'll deny all responsibility.
Old Jan 28, 2010 | 06:20 AM
They broke the knock sensor when removing the start motor.
£140 from Honda so its in their over night!
Old Jan 28, 2010 | 10:28 AM
FistralG's Avatar
I assume that's their cost, not yours? Did they not test drive it afterwards to make sure the car was OK before handing it over?!
Old Jan 28, 2010 | 11:33 PM
im unsure if they did but yes, they are paying for that. I will get the car back today and cant wait, havent been able to drive it hard since i bought it.
ade73
May 21, 2010 06:14 PM
Qiuness
Feb 14, 2010 07:19 PM
Dan Norton
Oct 9, 2009 06:16 AM
S2KCHRIS305
Oct 20, 2008 12:10 PM
tableskillz
Oct 18, 2008 04:47 PM
