Engine serial code
Old Nov 4, 2011 | 01:13 AM
TangoVTEC's Avatar
Default Engine serial code
On page 16 of the "above." service manual, it's shows the engine serial number as being slightly under the coolant bleed nipple, behind the aux belt tensioner.
Why can't I see it!!!
Old Nov 4, 2011 | 03:36 AM
Nick Graves's Avatar
It's slightly under the inlet manifold and almost f ucking impossible to read without removing the latter!
Best of luck...
Old Nov 4, 2011 | 03:38 AM
K3Nguru's Avatar
Like Nick said, it's hard to notice. I spent an hour looking for mine last year.
Old Nov 4, 2011 | 04:08 AM
Irish TuneR's Avatar
Best of luck...
Can you use a mirror to see it? I looked before as i was curious but gave up quick enough. Also is there anyway to check if its the original engine as well? Mines a JDM....
Old Nov 4, 2011 | 05:31 AM
WinFreak's Avatar
The serial no. would be the way to check if it's the original engine
Old Nov 4, 2011 | 05:32 AM
WinFreak's Avatar
Maybe you can try take a photo under the inlet mani and see it on there?
Old Nov 4, 2011 | 09:23 AM
TangoVTEC's Avatar
That's exactly the guidance I needed!
So if I was looking at the inlet side of the engine, it would be around under cylinder number one's port?
Old Nov 4, 2011 | 11:05 AM
WinFreak's Avatar
Yeh looks like it, haven't seen it for real though I plucked the photo of the internet
Old Nov 4, 2011 | 08:01 PM
Ultra_Nexus's Avatar
Originally Posted by Irish TuneR
Best of luck...
Yours should just be a F20C and not an F20C2
Best of luck...
CraigHew
Oct 8, 2014 12:00 AM
Friend of the Devil
Apr 17, 2007 12:20 PM
fireball
Oct 1, 2006 06:54 AM
Albert
Jun 5, 2002 02:37 PM
