Engine Swap
Old May 13, 2015 | 03:42 AM
BenRNBP's Avatar
You won't be able to use the 07 ECU on non-DBW, although I'd think about getting the throttle pedal and loom from the 07 and see if I could go the other way and convert to DBW, just in case I wanted to use Flash pro to tune in the future. I'm not sure if there are any gotchas like the CAN Bus modules for ABS, Air Bags controllers, etc but I suspect it might not be as easy as plug and play.
Old May 13, 2015 | 03:51 AM
BenRNBP's Avatar
...also I think the cam trigger wheels are different too - so you'll need swap those
jXxviii
Apr 28, 2014 09:24 PM
98RON
Sep 1, 2011 08:07 AM
scott-s2k
Nov 9, 2009 03:32 AM
s2kpearlwhite
Mar 12, 2009 09:08 AM
