UK & Ireland S2000 CommunityDiscussions related to the S2000, its ownership and enthusiasm for it in the UK and Ireland. Including FAQs, and technical questions.
drove to work this morning and everything was fine. finished work and got into the S, started the car and found that the power steering wasn't working and the eps light on!!!
stopped and started the car at least 5 times but still a problem. read that the power steering could start to work again if you drive a mile or so but that didnt work!!
any ideas what it could be? or is it a case of going to honda and emptying my pockets AGIAN;(
I found the eps fuse box that's located above the battery but all fuses seem fine. I've unplugged the battery now, I'll reconnect it in 7 or so hours time to see if there's a change.
I have a feeling Honda are gonna pull my pants down for this one
Did you check the battery voltage yet? preferably with it still connected to the car otherwise you might get a slightly higher/normal looking float voltage with no load on it..
Ok im in a situation now. Took the car to Honda and they had it for 30min. Still couldn't find out what the problem was! Now they want it for another 3/4 hours at £90 per hour!!!! Does anyone know of any Honda specialists around the midlands who could sort it out abit cheaper?
I bought my car expecting to have no problems as I had not 1 problem with my last, I've had this one for 2/3weeks and it's proberbly gonna cost another £300/400
