Alloys- 16 to 17
Alloys- 16 to 17
Had my S for 10 years now and still looks standard. Thinking about changing the alloys from 16 to 17 as the title suggests. Has anyone done this and has it altered the car or handling in any way. Or is it best to stay as is. Any thoughts welcome cheers rich.
I went from OEM 16 to OEM 17 and the car was more planted, less skittish with the extra width and on track you could carry much more speed and trail break with more control.
Would get an alignment done after fitting just to make sure its spot on.
Richie2garage (04-18-2018)
Always believe in getting things done right- so always use decent tyres running Bridgestone atm and will get an alignment done at the same time. I’ve seen some refurbished rotas on eBay and then I found some brand new ones for £40 more- bit of a no brainer! Thanks for your thoughts John and Chuck
The 17 wheels are heavier i believe so will probably increase unsprung mass which would lower grip on our less than utterrly shit roads
They do increase feel with less give in tyres imho
They look good
ultimately it's a personal choice
They look good
Richie2garage (04-19-2018)
Pay attention to the tread width up front as going wider will affect steering feel. The differences are not huge, but noticeable. I used to run the OEM 16" rims on the street and OEM 17" on the track. I noticed a small reduction in steering feel every time I switched to the track setup. The difference isn't large and without doing a back to back, it might not be noticeable. But thought I'd point that out.
If you do want to pay attention to this, pay attention to the tread width, not just the tire size. Some tire models are relatively narrow for a given stated tire width and others are wide. E.g. The Firestone 500 is rather narrow vs. the stated size as opposed to the Hankook RS-4 which is on the wide size. You can find these numbers on the tirerack.com website.
I went from OEM 16s to OEM 17s some years back. I cant recall noticing any significant difference. straight swap with no suspension adjustment needed.
IMHO they look better and also give a wider choice of tyre options.
A word of caution, some insurance companies would consider this to be a modification, which might cause problems if you make a claim and haven't told them. I told mine, no extra cost but at least they won't now be able to refuse a potential claim.
Richie2garage (04-20-2018)
Definitely a marked improvement getting 17's over 16's and insurance are okay as long as you tell them - along with alignment, get your bushes done if you've not already done them
To be clear, I'm not advising against the upgrade, just want to set expectations. I personally prefer the look of the 17" wheels with slightly wider tires but like the steering feel that comes from the lighter and narrower 16" front wheels. Like everything else, there are tradeoffs and you have to choose what matters most to you.
bobonacus
01-21-2017 07:48 AM
