Exhaust and intake - do I need an aftermarket ecu
I bought a K and n intake a while back to make the car sound better. Now my exhaust hangers have rusted and can't really be repaired. So I've got myself a custom single exit exhaust. So with these 2 mods do I need an ecu remap for potentially running too lean, I don't really want to buy an ecu etc ideally. Or will I be fine without.
Thanks for the info as always
Re-remap
I changed my intake and exhaust manifold and did notice a slight improvement in how the car drove. I then had the car remapped using a Hondata Flashpro, this made a big difference especially in the mid range. To use the Hondata the car must be my06 or younger.
How about full exhaust (header/test pipe/catback), intake and throttle body? Would probably need to port the intake manifold as well when using a bigger TB?
I assume this would need a remap, but what ECU is recommended for remapping an older model using only bolt-ons?
You run lean for a short period of time when vtec engages after that its fine, its only something you need to think about if you are on a track or for sustained periods of time.
Running a number of bolts like I/M/E of you run leaner more so at vtec andin WOT but nothing i would call dangerous - you need a tune to reap rewards anyways.
You have lots of choice really depends what your tuner is comfortable with, i tune S2000's with anything from simple VAFC2 through to a greddy emanage ultimate and AEM v2 standalone.
You can my feedback on here, facebook or my website.
Bubbels** (04-16-2018)
So from the little research I did and from all your responses - thank you - the conclusion reached is no remap required in terms of engine safety from just an exhaust and ecu.
FYI for those interested my custom single exit exhaust that I bought from a guy on fb sounds insane along with the K and n intake. It's quite loud although I've got nothing to compare to but it's a welcome change after 3 years.
lalakis2000
06-15-2008 01:04 AM
