Fast Road Set Up
Fast Road Set Up
Has anyone had a fast road set up done on their S2000?
Fitting meister-r coliovers in the coming weeks and was wondering if i should get a fast road set up to go alongside them. Would probably take it to revolution motorstore in Gateshead, unless anyone can suggest somewhere better (preferably in the Newcastle area).
Thanks.
Thanks.
Possibly should have elaborated a little. Basically a 4-wheel alignment, to adjust camber,caster,toe etc.
Just wondering if it is worthwhile after installing coilovers or should i just stick with OEM settings?
In my limited experience, fitting aftermarket coilovers means that certain single track b-roads (around Buxton certainly) become 'Satans Alley' and are barely enjoyable, even on full soft!
So your 'fast roads' where are they?
Changing suspension is always a compromise, so are you going to track your S or do you like hooning down pot-holed, off camber, rutted b-roads?
