Final ICE setup
That is a good "building block" system. It will make a major difference over the stock stuff!
Don't forget the 20A battery feed. The rest uses the honda wiring looms!
Installed most of mine today, just need to get the speakers in
Didn't realise it would need a seperate battery feed?!
Think I will have to get this fitted professionally unless there is anyone in the Leeds area who would give me a hand for the price of a couple of pints and my good company
Originally Posted by Bassoctopus,Jul 2 2005, 09:15 PM
I didn't run a battery feed on my Alpine unit (9843).
Me being fussy the Alpine manual states a permanent feed from the battery.
I am amped up so I did it to the letter.
If you are using the internal amp you may be alright with either Bass's or Steve's approach - try it. Its not difficult to change it! The unit will come with a bit of cable and the fuse holder built into its loom.
MrV has a valid point but this means a bit more work and thought, I didn't leave those cables in
Don't get too hung up on the install of this system - it is very straight forward. A bit worrying first time but you'll be fine!
HU will plug in to KCE which plugs in to Honda loom.
If Steve and Bass are right all you need to do is plug in the earth in (I left the cable there!)
Now whip the door cards off
Unscrew the Honda speakers (you will need an adaptor to go from the Honda speaker connectors to the Alpines!)
The baskets and mounting holes are already set up for 6.5" speakers!
Refit panels!
Job Done
For more info check out these links
https://www.s2ki.com/forums/index.php?showtopic=295344
https://www.s2ki.com/forums/index.php?showtopic=248785
https://www.s2ki.com/forums/index.php?showtopic=130106
Now get out there and drive it James
I'm off to try out my new Volks and geo!
!!Don't get too hung up on the install of this system - it is very straight forward. A bit worrying first time but you'll be fine!
Refit panels!
Job Done
AndyDoh
Nov 28, 2003 11:40 AM
