Fitted Them Today!!!!
My dual Fiamm horns and I'm here to tell you they really rock!!!
Biker 1's advice saved me a lot of time and trouble.(Thanks Nigel) I just couldn't live with that farty little stock horn any longer. Mmm what's my next mod???
Originally posted by AnDy_PaNdY
Any tips ??
Any tips ??
Soon I'll be able to hear you car from here Tonky!
Why not point the air horns backwards - the jet boost effect
Anyone going for quad horns?
Seriously, I think I'll upgrade the horn sooner or later... At Bentwaters Andy W. had to use his horn once.... it's even more embarrising in the company of a lot of nice cars/owners...
-Brian.
-Brian.
Tonky, they are air horns, right? I've had problems with airhorns is the past with moisture and crud getting into the compressor and with your UK climate, I think this may be a problem there, too. The compressor inards eventually get corroded and either seize up or don't blow air well. I remember the instructions said something about putting a couple drops of oil into the lube orifice and blowing the horn a couple times. Should do it every couple of months or so. Had I done that when I had mine years ago, I may have NOT gotten dissillusioned with air horns. I have the Fiamm non-air horns. Cheers.
Xviper:
Thanks. That sort of ties in what I'd heard, but I'm gonna take my time over the install and see if I can make it as waterproof as possible If it all goes to rats*** I can always put the others back.
