Fitting remote locking
My USA MY06 remote is G8D-452H-A. No frequency listed. Note the difference which may be significant. Same maker. I know this works in US cars as a buddy bought one off Ebay and programmed it to his MY02 car a couple of months ago.
-- Chuck
-- Chuck
What a guy, cheers!
Edit+
One of these theoretically should do the trick then:
http://www.ebay.co.uk/ulk/itm/161934934332
http://www.ebay.co.uk/ulk/itm/371532315398
Albeit the latter with a new case perhaps.
I've just relocated to Cardiff so I'll find my nearest Honda dealer and enquire. Many thanks.
Edit+
Have you had any luck with this yet? as I'd like to do the same.
So I just went into Honda Cardiff. They said they didn't really know but can't see why not, so I'll go ahead and order a used fob off eBay or the like and take the car down to them. If that fails then I'll look for an auto locksmith technician.
As long as the transceiver is still there I can't see there being an issue.
Received it this morning & easily programmed it on the driveway. Took less than a minute.
Only thing not working is the boot release so I'll have to look into that now.
FYI I used these instruction:
Close doors, hood, trunk.
1. Ignition ON.
2. Within 1-4 secs. push lock or unlock while aiming the remote at the receiver.
3. Within 1-4 secs, turn OFF ignition.
4. Within 1-4 secs, turn ON ign.
5. Within 1-4 secs, repeat (2.)
6. Within 1-4 secs, turn OFF ign.
7. Within 4 secs, turn ON ign.
8. Within 1-4 secs, repeat (2.)
9. Within 1-4 secs, turn OFF ign.
10. Within 4 secs, turn ON ign.
11. Within 1-4 secs, repeat (2.)
12. Confirm that you hear the door lock actuators. Within 1-4 secs, push the transmitter lock or unlock button again. The keyless receiver is now in the program mode. You must push the transmitter lock or unlock button of the first transmitter again to program that remote.
13. Within 10 secs, aim the transmitters (up to three) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn ign. OFF, and pull out the key.
15. Confirm the operation of the new codes.
1. Ignition ON.
